{"name":"vespania","description":"La web de los usuarios de Vespa, LML y Lambretta","url":"https:\/\/vespania.es","home":"https:\/\/vespania.es","gmt_offset":"2","timezone_string":"","page_for_posts":0,"page_on_front":0,"show_on_front":"posts","namespaces":["oembed\/1.0","cleantalk-antispam\/v1","contact-form-7\/v1","h5vp\/v1","mailin\/v1","responsive_pro\/v1","cc\/v1","rankmath\/v1","rankmath\/v1\/setupWizard","rankmath\/v1\/ca","rankmath\/v1\/an","rankmath\/v1\/in","rankmath\/v1\/status","google-site-kit\/v1","aios\/v1\/onboarding","wp\/v2","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/vespania.es\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"La URL del recurso del que recuperar los datos oEmbed.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"La URL del recurso del que recuperar los datos oEmbed.","type":"string","format":"uri","required":true},"format":{"description":"El formato oEmbed a utilizar.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"La anchura m\u00e1xima del marco de incrustaci\u00f3n en p\u00edxeles.","type":"integer","default":600,"required":false},"maxheight":{"description":"La altura m\u00e1xima del marco de incrustaci\u00f3n en p\u00edxeles.","type":"integer","required":false},"discover":{"description":"Si se realizar\u00e1 una petici\u00f3n de descubrimiento de oEmbed para proveedores no sancionados.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/oembed\/1.0\/proxy"}]}},"\/cleantalk-antispam\/v1":{"namespace":"cleantalk-antispam\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"cleantalk-antispam\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/cleantalk-antispam\/v1"}]}},"\/cleantalk-antispam\/v1\/js_keys__get":{"namespace":"cleantalk-antispam\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/cleantalk-antispam\/v1\/js_keys__get"}]}},"\/cleantalk-antispam\/v1\/apbct_get_pixel_url":{"namespace":"cleantalk-antispam\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/cleantalk-antispam\/v1\/apbct_get_pixel_url"}]}},"\/cleantalk-antispam\/v1\/alt_sessions":{"namespace":"cleantalk-antispam\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"cookies":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/cleantalk-antispam\/v1\/alt_sessions"}]}},"\/cleantalk-antispam\/v1\/check_email_before_post":{"namespace":"cleantalk-antispam\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"email":{"type":"email","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/cleantalk-antispam\/v1\/check_email_before_post"}]}},"\/cleantalk-antispam\/v1\/check_email_exist_post":{"namespace":"cleantalk-antispam\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"email":{"type":"email","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/cleantalk-antispam\/v1\/check_email_exist_post"}]}},"\/cleantalk-antispam\/v1\/apbct_decode_email":{"namespace":"cleantalk-antispam\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"encodedEmails":{"type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/cleantalk-antispam\/v1\/apbct_decode_email"}]}},"\/cleantalk-antispam\/v1\/apbct_rest_check":{"namespace":"cleantalk-antispam\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/cleantalk-antispam\/v1\/apbct_rest_check"}]}},"\/cleantalk-antispam\/v1\/force_protection_check_bot":{"namespace":"cleantalk-antispam\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"event_javascript_data":{"type":"array","required":false},"event_token":{"type":"string","required":false},"post_url":{"type":"string","required":true},"referrer":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/cleantalk-antispam\/v1\/force_protection_check_bot"}]}},"\/contact-form-7\/v1":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"contact-form-7\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/contact-form-7\/v1"}]}},"\/contact-form-7\/v1\/contact-forms":{"namespace":"contact-form-7\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/contact-form-7\/v1\/contact-forms"}]}},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)":{"namespace":"contact-form-7\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/feedback":{"namespace":"contact-form-7\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/feedback\/schema":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/refill":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/h5vp\/v1":{"namespace":"h5vp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"h5vp\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/h5vp\/v1"}]}},"\/h5vp\/v1\/video":{"namespace":"h5vp\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/h5vp\/v1\/video"}]}},"\/h5vp\/v1\/video\/(?P<id>\\d+)":{"namespace":"h5vp\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]}]},"\/h5vp\/v1\/analytics":{"namespace":"h5vp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/h5vp\/v1\/analytics"}]}},"\/mailin\/v1":{"namespace":"mailin\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"mailin\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/mailin\/v1"}]}},"\/mailin\/v1\/testconnection":{"namespace":"mailin\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/mailin\/v1\/testconnection"}]}},"\/mailin\/v1\/mailin_disconnect":{"namespace":"mailin\/v1","methods":["DELETE"],"endpoints":[{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/mailin\/v1\/mailin_disconnect"}]}},"\/responsive_pro\/v1":{"namespace":"responsive_pro\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"responsive_pro\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/responsive_pro\/v1"}]}},"\/responsive_pro\/v1\/rpro_mega_menu\/(?P<id>\\d+)":{"namespace":"responsive_pro\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/responsive_pro\/v1\/rpro_mega_menu":{"namespace":"responsive_pro\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/responsive_pro\/v1\/rpro_mega_menu"}]}},"\/cc\/v1":{"namespace":"cc\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"cc\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/cc\/v1"}]}},"\/cc\/v1\/settings":{"namespace":"cc\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/cc\/v1\/settings"}]}},"\/rankmath\/v1":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1"}]}},"\/rankmath\/v1\/saveModule":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"module":{"type":"string","description":"Slug del m\u00f3dulo","required":true},"state":{"type":"string","description":"Estado del m\u00f3dulo activado o desactivado","enum":["on","off"],"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/saveModule"}]}},"\/rankmath\/v1\/toolsAction":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"action":{"type":"string","description":"Acci\u00f3n a realizar","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/toolsAction"}]}},"\/rankmath\/v1\/updateMode":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"mode":{"type":"string","description":"Modo a establecer","enum":["easy","advanced","custom"],"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/updateMode"}]}},"\/rankmath\/v1\/dashboardWidget":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/dashboardWidget"}]}},"\/rankmath\/v1\/updateSeoScore":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"postScores":{"type":"object","description":"Puntuaciones de la entrada","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/updateSeoScore"}]}},"\/rankmath\/v1\/updateSettings":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/updateSettings"}]}},"\/rankmath\/v1\/searchPage":{"namespace":"rankmath\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/searchPage"}]}},"\/rankmath\/v1\/disconnectSite":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"token":{"type":"string","description":"Token del sitio","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/disconnectSite"}]}},"\/rankmath\/v1\/getFeaturedImageId":{"namespace":"rankmath\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"postId":{"type":"integer","description":"ID de la entrada","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/getFeaturedImageId"}]}},"\/rankmath\/v1\/updateRedirection":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"objectID":{"type":"integer","description":"ID \u00fanico del objeto","required":true},"objectType":{"type":"string","default":"post","description":"Tipo de objeto. P.ej. entrada, t\u00e9rmino, usuario","required":true},"hasRedirect":{"type":"boolean","description":"Si el objeto tiene una redirecci\u00f3n o no","required":true},"redirectionID":{"type":"string","description":"ID de redirecci\u00f3n","required":false},"redirectionUrl":{"type":"string","description":"URL de redirecci\u00f3n","required":false},"redirectionType":{"type":"string","default":"301","description":"Tipo de redirecci\u00f3n","enum":["301","302","307","410","451"],"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/updateRedirection"}]}},"\/rankmath\/v1\/updateMeta":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"objectType":{"type":"string","description":"Tipo de objeto. P.ej. entrada, t\u00e9rmino, usuario","required":true},"objectID":{"type":"integer","description":"ID \u00fanico del objeto","required":true},"meta":{"description":"Meta para a\u00f1adir o actualizar datos.","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/updateMeta"}]}},"\/rankmath\/v1\/updateSchemas":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"objectType":{"type":"string","description":"Tipo de objeto. P.ej. entrada, t\u00e9rmino, usuario","required":true},"objectID":{"type":"integer","description":"ID \u00fanico del objeto","required":true},"schemas":{"description":"schemas para a\u00f1adir o actualizar datos.","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/updateSchemas"}]}},"\/rankmath\/v1\/updateMetaBulk":{"namespace":"rankmath\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"rows":{"description":"Entradas seleccionadas para actualizar los datos.","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/updateMetaBulk"}]}},"\/rankmath\/v1\/setupWizard":{"namespace":"rankmath\/v1\/setupWizard","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/setupWizard","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/setupWizard"}]}},"\/rankmath\/v1\/setupWizard\/getStepData":{"namespace":"rankmath\/v1\/setupWizard","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"step":{"type":"string","description":"Paso actual","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/setupWizard\/getStepData"}]}},"\/rankmath\/v1\/setupWizard\/updateStepData":{"namespace":"rankmath\/v1\/setupWizard","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"step":{"type":"string","description":"Paso actual","required":true},"value":{"type":"object","description":"Datos del paso actual","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/setupWizard\/updateStepData"}]}},"\/rankmath\/v1\/setupWizard\/updateTrackingOptin":{"namespace":"rankmath\/v1\/setupWizard","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"enable_tracking":{"type":"string","description":"Activar seguimiento","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/setupWizard\/updateTrackingOptin"}]}},"\/rankmath\/v1\/ca":{"namespace":"rankmath\/v1\/ca","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/ca","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/ca"}]}},"\/rankmath\/v1\/ca\/researchKeyword":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keyword":{"description":"La palabra clave a analizar.","type":"string","required":true},"country":{"description":"El pa\u00eds para el que debe analizarse la palabra clave.","type":"string","required":true},"objectID":{"description":"ID de la entrada que inicia la solicitud de an\u00e1lisis de palabras clave.","type":"integer","required":true},"force_update":{"description":"Si es true, fuerza una nueva solicitud de an\u00e1lisis.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/ca\/researchKeyword"}]}},"\/rankmath\/v1\/ca\/getCredits":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/ca\/getCredits"}]}},"\/rankmath\/v1\/ca\/createPost":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"content":{"description":"El contenido de la nueva entrada.","type":"string","required":true},"title":{"description":"El t\u00edtulo de la nueva entrada.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/ca\/createPost"}]}},"\/rankmath\/v1\/ca\/saveOutput":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"outputs":{"description":"Un array de resultados generados por la IA y existentes a guardar.","type":"array","required":true},"endpoint":{"description":"La variable de la API para la que se gener\u00f3 el resultado.","type":"string","required":true},"isChat":{"description":"Indica si la solicitud era para la variable Chat.","type":"boolean","required":false},"attributes":{"description":"Los par\u00e1metros utilizados para generar el resultado de la IA.","type":"object","required":false},"credits":{"description":"Detalles de uso del cr\u00e9dito devueltos por la API.","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/ca\/saveOutput"}]}},"\/rankmath\/v1\/ca\/deleteOutput":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"isChat":{"description":"Indica si la solicitud para borrar el resultado fue para la variable Chat.","type":"boolean","required":false},"index":{"description":"El \u00edndice de resultados a borrar, aplicable s\u00f3lo a la variable Chat.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/ca\/deleteOutput"}]}},"\/rankmath\/v1\/ca\/updateRecentPrompt":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"prompt":{"description":"La indicaci\u00f3n seleccionada se actualizar\u00e1 en las indicaciones recientes.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/ca\/updateRecentPrompt"}]}},"\/rankmath\/v1\/ca\/updatePrompt":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"prompt":{"description":"Los datos de indicaciones que se guardar\u00e1n en la base de datos.","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/ca\/updatePrompt"}]}},"\/rankmath\/v1\/ca\/savePrompts":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"prompts":{"description":"Lista de indicaciones recibidas de la API que se guardar\u00e1n en la base de datos.","type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/ca\/savePrompts"}]}},"\/rankmath\/v1\/ca\/pingContentAI":{"namespace":"rankmath\/v1\/ca","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"plan":{"description":"Contenido que la IA tiene previsto actualizar en la base de datos.","type":"string","required":true},"refreshDate":{"description":"Fecha de restablecimiento de la IA de contenido para actualizar en la base de datos","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/ca\/pingContentAI"}]}},"\/rankmath\/v1\/ca\/generateAlt":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"attachmentIds":{"description":"List  de IDs de adjuntos para los que generar el texto alt.","type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/ca\/generateAlt"}]}},"\/rankmath\/v1\/ca\/updateCredits":{"namespace":"rankmath\/v1\/ca","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"credits":{"description":"Detalles de uso del cr\u00e9dito devueltos por la API.","type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/ca\/updateCredits"}]}},"\/rankmath\/v1\/an":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/an","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/an"}]}},"\/rankmath\/v1\/an\/dashboard":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/an\/dashboard"}]}},"\/rankmath\/v1\/an\/keywordsOverview":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/an\/keywordsOverview"}]}},"\/rankmath\/v1\/an\/postsSummary":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/an\/postsSummary"}]}},"\/rankmath\/v1\/an\/postsRowsByObjects":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/an\/postsRowsByObjects"}]}},"\/rankmath\/v1\/an\/post\/(?P<id>\\d+)":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID de la entrada.","type":"integer","required":true}}}]},"\/rankmath\/v1\/an\/keywordsSummary":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/an\/keywordsSummary"}]}},"\/rankmath\/v1\/an\/analyticsSummary":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"postType":{"description":"Tipo de contenido.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/an\/analyticsSummary"}]}},"\/rankmath\/v1\/an\/keywordsRows":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"N\u00famero de p\u00e1gina.","type":"integer","required":false},"perPage":{"description":"Resultados por p\u00e1gina.","type":"integer","required":false},"orderBy":{"description":"Ordenar por.","type":"string","required":false},"order":{"description":"Orden.","type":"string","required":false},"search":{"description":"B\u00fasqueda.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/an\/keywordsRows"}]}},"\/rankmath\/v1\/an\/userPreferences":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"preferences":{"description":"Preferencias de usuario.","type":"object","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/an\/userPreferences"}]}},"\/rankmath\/v1\/an\/inspectionResults":{"namespace":"rankmath\/v1\/an","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"N\u00famero de p\u00e1gina.","type":"integer","required":false},"perPage":{"description":"Resultados por p\u00e1gina.","type":"integer","required":false},"orderBy":{"description":"Ordenar por.","type":"string","required":false},"order":{"description":"Orden.","type":"string","required":false},"search":{"description":"B\u00fasqueda.","type":"string","required":false},"filter":{"description":"Filtro.","type":"string","required":false},"filterType":{"description":"Tipo de filtro.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/an\/inspectionResults"}]}},"\/rankmath\/v1\/an\/removeFrontendStats":{"namespace":"rankmath\/v1\/an","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"toggleBar":{"description":"Barra de alternar.","type":"boolean","required":false},"hide":{"description":"Ocultar.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/an\/removeFrontendStats"}]}},"\/rankmath\/v1\/in":{"namespace":"rankmath\/v1\/in","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/in","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/in"}]}},"\/rankmath\/v1\/in\/submitUrls":{"namespace":"rankmath\/v1\/in","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"urls":{"description":"La lista de URLs a enviar a la API de indexado instant\u00e1neo.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/in\/submitUrls"}]}},"\/rankmath\/v1\/in\/getLog":{"namespace":"rankmath\/v1\/in","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"filter":{"description":"Filtrar registro por tipo.","type":"string","enum":["all","manual","auto"],"default":"all","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/in\/getLog"}]}},"\/rankmath\/v1\/in\/clearLog":{"namespace":"rankmath\/v1\/in","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"filter":{"description":"Vaciar registro por tipo.","type":"string","enum":["all","manual","auto"],"default":"all","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/in\/clearLog"}]}},"\/rankmath\/v1\/in\/resetKey":{"namespace":"rankmath\/v1\/in","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/in\/resetKey"}]}},"\/rankmath\/v1\/links\/posts":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"N\u00famero de p\u00e1gina.","type":"integer","default":1,"required":false},"per_page":{"description":"Items per page.","type":"integer","default":50,"maximum":100,"required":false},"search":{"description":"Search in post title.","type":"string","default":"","required":false},"post_type":{"description":"Filter by post type. Supports multiple values.","type":"array","items":{"type":"string"},"default":[],"required":false},"is_orphan":{"description":"Filter by orphan status (orphan, linked).","type":"string","default":"","required":false},"seo_score_range":{"description":"Filter by SEO score range (great, good, bad, no-score).","type":"string","default":"","required":false},"orderby":{"description":"Order by field.","type":"string","default":"post_title","required":false},"order":{"description":"Order direction (ASC, DESC).","type":"string","default":"ASC","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/links\/posts"}]}},"\/rankmath\/v1\/links\/posts-stats":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/links\/posts-stats"}]}},"\/rankmath\/v1\/links\/links":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page":{"description":"N\u00famero de p\u00e1gina.","type":"integer","default":1,"required":false},"per_page":{"description":"Items per page.","type":"integer","default":50,"maximum":100,"required":false},"search":{"description":"Search in URL.","type":"string","default":"","required":false},"source_id":{"description":"Filter by source post ID.","type":"integer","default":0,"required":false},"target_post_id":{"description":"Filter by target post ID.","type":"integer","default":0,"required":false},"is_internal":{"description":"Filter by link type (1 = internal, 0 = external).","type":"string","default":"","required":false},"orderby":{"description":"Order by field.","type":"string","default":"id","required":false},"order":{"description":"Order direction (ASC, DESC).","type":"string","default":"DESC","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/links\/links"}]}},"\/rankmath\/v1\/links\/links-stats":{"namespace":"rankmath\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/links\/links-stats"}]}},"\/rankmath\/v1\/status":{"namespace":"rankmath\/v1\/status","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"rankmath\/v1\/status","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/status"}]}},"\/rankmath\/v1\/status\/getViewData":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/status\/getViewData"}]}},"\/rankmath\/v1\/status\/updateViewData":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/status\/updateViewData"}]}},"\/rankmath\/v1\/status\/importSettings":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/status\/importSettings"}]}},"\/rankmath\/v1\/status\/exportSettings":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/status\/exportSettings"}]}},"\/rankmath\/v1\/status\/runBackup":{"namespace":"rankmath\/v1\/status","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/rankmath\/v1\/status\/runBackup"}]}},"\/google-site-kit\/v1":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"google-site-kit\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1"}]}},"\/google-site-kit\/v1\/core\/site\/data\/setup-tag":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/setup-tag"}]}},"\/google-site-kit\/v1\/core\/site\/data\/connection":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/connection"}]}},"\/google-site-kit\/v1\/core\/user\/data\/authentication":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/authentication"}]}},"\/google-site-kit\/v1\/core\/user\/data\/disconnect":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/disconnect"}]}},"\/google-site-kit\/v1\/core\/user\/data\/get-token":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/get-token"}]}},"\/google-site-kit\/v1\/core\/user\/data\/user-input-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"questions":{"purpose":{"type":"array","items":{"type":"string"}},"postFrequency":{"type":"array","items":{"type":"string"}},"goals":{"type":"array","items":{"type":"string"}},"includeConversionEvents":{"type":"array","items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/user-input-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/audience-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"configuredAudiences":{"type":"array","items":{"type":"string"}},"isAudienceSegmentationWidgetHidden":{"type":"boolean"},"didSetAudiences":{"type":"boolean"}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/audience-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/conversion-reporting-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"newEventsCalloutDismissedAt":{"type":"integer"},"lostEventsCalloutDismissedAt":{"type":"integer"}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/conversion-reporting-settings"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/list":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/list"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/activation":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/activation"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/info":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identificador del m\u00f3dulo.","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/info"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/check-access":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identificador del m\u00f3dulo.","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/check-access"}]}},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/notifications":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identificador del m\u00f3dulo.","default":null,"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identificador del m\u00f3dulo.","default":null,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identificador del m\u00f3dulo.","default":null,"required":false},"data":{"type":"object","description":"Ajustes para establecer.","default":null,"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/data-available":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"slug":{"type":"string","description":"Identificador del m\u00f3dulo.","default":null,"required":false}}}]},"\/google-site-kit\/v1\/modules\/(?P<slug>[a-z0-9\\-]+)\/data\/(?P<datapoint>[a-z\\-]+)":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"slug":{"type":"string","description":"Identificador del m\u00f3dulo.","default":null,"required":false},"datapoint":{"type":"string","description":"Los datos del m\u00f3dulo apuntan a la direcci\u00f3n.","default":null,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"slug":{"type":"string","description":"Identificador del m\u00f3dulo.","default":null,"required":false},"datapoint":{"type":"string","description":"Los datos del m\u00f3dulo apuntan a la direcci\u00f3n.","default":null,"required":false},"data":{"type":"object","description":"Datos a configurar.","default":null,"required":false}}}]},"\/google-site-kit\/v1\/core\/modules\/data\/recover-modules":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/recover-modules"}]}},"\/google-site-kit\/v1\/core\/modules\/data\/sharing-settings":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/modules\/data\/sharing-settings"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-items":{"namespace":"google-site-kit\/v1","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["DELETE"],"args":{"data":{"type":"object","description":"","default":null,"minProperties":1,"additionalProperties":false,"properties":{"slugs":{"type":"array","required":true,"items":{"type":"string"}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-items"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-item":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-item"}]}},"\/google-site-kit\/v1\/core\/user\/data\/expirable-items":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/expirable-items"}]}},"\/google-site-kit\/v1\/core\/user\/data\/set-expirable-item-timers":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"array","description":"","default":null,"items":{"type":"object","additionalProperties":false,"properties":{"slug":{"type":"string","required":true},"expiration":{"type":"integer","required":true}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/set-expirable-item-timers"}]}},"\/google-site-kit\/v1\/core\/user\/data\/permissions":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/permissions"}]}},"\/google-site-kit\/v1\/core\/user\/data\/nonces":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/nonces"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-trigger":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"triggerID":{"type":"string","required":true},"ttl":{"type":"integer","minimum":0}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-trigger"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-event":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"session":{"type":"object","required":true,"properties":{"session_id":{"type":"string","required":true},"session_token":{"type":"string","required":true}}},"event":{"type":"object","required":true,"properties":{"survey_shown":{"type":"object"},"survey_closed":{"type":"object"},"question_answered":{"type":"object"},"completion_shown":{"type":"object"},"follow_up_link_clicked":{"type":"object"}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-event"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey-timeouts":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey-timeouts"}]}},"\/google-site-kit\/v1\/core\/user\/data\/survey":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/survey"}]}},"\/google-site-kit\/v1\/core\/site\/data\/reset":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/reset"}]}},"\/google-site-kit\/v1\/core\/site\/data\/reset-persistent":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/reset-persistent"}]}},"\/google-site-kit\/v1\/core\/site\/data\/developer-plugin":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/developer-plugin"}]}},"\/google-site-kit\/v1\/core\/user\/data\/tracking":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"enabled":{"type":"boolean","required":true}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/tracking"}]}},"\/google-site-kit\/v1\/core\/search\/data\/entity-search":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"query":{"type":"string","description":"Contenido de texto por el que buscar.","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/search\/data\/entity-search"}]}},"\/google-site-kit\/v1\/core\/site\/data\/admin-bar-settings":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"enabled":{"type":"boolean","required":false}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/admin-bar-settings"}]}},"\/google-site-kit\/v1\/core\/site\/data\/notifications":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/notifications"}]}},"\/google-site-kit\/v1\/core\/site\/data\/mark-notification":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/mark-notification"}]}},"\/google-site-kit\/v1\/core\/site\/data\/site-health-tag-placement-test":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/site-health-tag-placement-test"}]}},"\/google-site-kit\/v1\/core\/site\/data\/health-checks":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/health-checks"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-tours":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-tours"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-tour":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-tour"}]}},"\/google-site-kit\/v1\/core\/user\/data\/key-metrics":{"namespace":"google-site-kit\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"properties":{"isWidgetHidden":{"type":"boolean","required":true},"widgetSlugs":{"type":"array","required":false,"maxItems":8,"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/key-metrics"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismissed-prompts":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismissed-prompts"}]}},"\/google-site-kit\/v1\/core\/user\/data\/dismiss-prompt":{"namespace":"google-site-kit\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"object","description":"","default":null,"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/user\/data\/dismiss-prompt"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-mode":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"minProperties":1,"additionalProperties":false,"properties":{"enabled":{"type":"boolean"},"regions":{"type":"array","items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-mode"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-api-info":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-api-info"}]}},"\/google-site-kit\/v1\/core\/site\/data\/consent-api-activate":{"namespace":"google-site-kit\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/consent-api-activate"}]}},"\/google-site-kit\/v1\/core\/site\/data\/ads-measurement-status":{"namespace":"google-site-kit\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/ads-measurement-status"}]}},"\/google-site-kit\/v1\/core\/site\/data\/conversion-tracking":{"namespace":"google-site-kit\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"data":{"type":"object","description":"","default":null,"properties":{"settings":{"type":"object","required":true,"properties":{"enabled":{"type":"boolean","required":true}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/google-site-kit\/v1\/core\/site\/data\/conversion-tracking"}]}},"\/aios\/v1\/onboarding":{"namespace":"aios\/v1\/onboarding","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"aios\/v1\/onboarding","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/aios\/v1\/onboarding"}]}},"\/aios\/v1\/onboarding\/tfa_key_is_valid":{"namespace":"aios\/v1\/onboarding","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/aios\/v1\/onboarding\/tfa_key_is_valid"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar el conjunto de resultados a las publicaciones asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Asegurar que el conjunto de resultados excluye las publicaciones asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita el conjunto de resultados en base a la relaci\u00f3n entre m\u00faltiples taxonom\u00edas.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda categories.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Si se incluyen los t\u00e9rminos hijos en los t\u00e9rminos que limitan el conjunto de resultados.","type":"boolean","default":false},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda categories.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Si se incluyen los t\u00e9rminos hijos en los t\u00e9rminos que limitan el conjunto de resultados.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda tags.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda tags.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Limitar el conjunto de resultados a elementos que sean fijos.","type":"boolean","required":false},"ignore_sticky":{"description":"Ignorar (o no) las entradas fijas.","type":"boolean","default":true,"required":false},"format":{"description":"Limita el conjunto de resultados a los elementos asignados a uno o varios formatos dados.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"El formato de la entrada.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Si se debe tratar la entrada como fija o no.","type":"boolean","required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"categories":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda post_tag.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Anula la longitud por defecto del extracto.","type":"integer","required":false},"password":{"description":"La contrase\u00f1a para la entrada, si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"El formato de la entrada.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Si se debe tratar la entrada como fija o no.","type":"boolean","required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"categories":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda post_tag.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"El formato de la entrada.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"Si se debe tratar la entrada como fija o no.","type":"boolean","required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"categories":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda post_tag.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar el conjunto de resultados a las publicaciones asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Asegurar que el conjunto de resultados excluye las publicaciones asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limitar los resultados a entradas con un valor espec\u00edfico `menu_order`.","type":"integer","required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Limitar los resultados a los que tengan IDs superiores concretos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limitar los resultados a todos los elementos excepto aquellos con un identificador padre espec\u00edfico.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"parent":{"description":"El ID del superior de la entrada.","type":"integer","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"El orden de la entrada en relaci\u00f3n con otras entradas.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Anula la longitud por defecto del extracto.","type":"integer","required":false},"password":{"description":"La contrase\u00f1a para la entrada, si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"parent":{"description":"El ID del superior de la entrada.","type":"integer","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"El orden de la entrada en relaci\u00f3n con otras entradas.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID del superior de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"El orden de la entrada en relaci\u00f3n con otras entradas.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar el conjunto de resultados a las publicaciones asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"Asegurar que el conjunto de resultados excluye las publicaciones asignadas a autores espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Limitar los resultados a los que tengan IDs superiores concretos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limitar los resultados a todos los elementos excepto aquellos con un identificador padre espec\u00edfico.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Limitar el conjunto de resultados a adjuntos de un tipo o tipos de medio en particular.","type":"array","items":{"type":"string","enum":["image","video","text","application","audio"]},"required":false},"mime_type":{"default":null,"description":"Limitar el conjunto de resultados a adjuntos de un tipo o tipos MIME en particular.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"alt_text":{"description":"Texto alternativo a mostrar cuando no se muestra el adjunto.","type":"string","required":false},"caption":{"description":"Leyenda del adjunto.","type":"object","properties":{"raw":{"description":"Leyenda del adjunto, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Leyenda HTML del adjunto, transformada para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n del adjunto","type":"object","properties":{"raw":{"description":"Descripci\u00f3n del adjunto, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Descripci\u00f3n HTML del adjunto, transformada para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"El ID de las entradas a las que est\u00e1 asociado el adjunto.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"El ID del autor de la entrada.","type":"integer","required":false},"featured_media":{"description":"El ID de la imagen destacada para la entrada.","type":"integer","required":false},"comment_status":{"description":"Si los comentarios est\u00e1n abiertos en la entrada o no.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"Si se puede hacer ping a la entrada o no.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"alt_text":{"description":"Texto alternativo a mostrar cuando no se muestra el adjunto.","type":"string","required":false},"caption":{"description":"Leyenda del adjunto.","type":"object","properties":{"raw":{"description":"Leyenda del adjunto, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Leyenda HTML del adjunto, transformada para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n del adjunto","type":"object","properties":{"raw":{"description":"Descripci\u00f3n del adjunto, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Descripci\u00f3n HTML del adjunto, transformada para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"El ID de las entradas a las que est\u00e1 asociado el adjunto.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identificador \u00fanico para el adjunto.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL al archivo de la imagen editada.","type":"string","format":"uri","required":true},"modifiers":{"description":"Array de las ediciones de la imagen.","type":"array","minItems":1,"items":{"description":"Edici\u00f3n de im\u00e1genes.","type":"object","required":["type","args"],"oneOf":[{"title":"Voltear","properties":{"type":{"description":"Tipo de volteo.","type":"string","enum":["flip"]},"args":{"description":"Argumentos del volteo.","type":"object","required":["flip"],"properties":{"flip":{"description":"Direcci\u00f3n de volteo.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"Si se debe voltear en direcci\u00f3n horizontal.","type":"boolean"},"vertical":{"description":"Si se debe voltear en direcci\u00f3n vertical.","type":"boolean"}}}}}}},{"title":"Rotaci\u00f3n","properties":{"type":{"description":"Tipo de rotaci\u00f3n.","type":"string","enum":["rotate"]},"args":{"description":"Argumentos de rotaci\u00f3n.","type":"object","required":["angle"],"properties":{"angle":{"description":"\u00c1ngulo a rotar en el sentido de las agujas del reloj en grados.","type":"number"}}}}},{"title":"Recortar","properties":{"type":{"description":"Tipo de recorte.","type":"string","enum":["crop"]},"args":{"description":"Argumentos de recorte.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Posici\u00f3n horizontal desde la izquierda para iniciar el recorte como un porcentaje del ancho de la imagen.","type":"number"},"top":{"description":"Posici\u00f3n vertical desde la parte superior para iniciar el recorte como un porcentaje de la altura de la imagen.","type":"number"},"width":{"description":"Ancho del recorte como un porcentaje del ancho de la imagen.","type":"number"},"height":{"description":"Altura del recorte como un porcentaje de la altura de la imagen.","type":"number"}}}}}]},"required":false},"rotation":{"description":"La cantidad a girar la imagen en el sentido de las agujas del reloj en grados. OBSOLETO: Usa `modifiers` en su lugar.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"Como un porcentaje de la imagen, la posici\u00f3n del eje X desde la que iniciar el recorte. OBSOLETO: Usa `modifiers` en su lugar.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"Como un porcentaje de la imagen, la posici\u00f3n del eje Y desde la que iniciar el recorte. OBSOLETO: Usa `modifiers` en su lugar.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"Como un porcentaje de la imagen, el ancho al que recortar la imagen. OBSOLETO: Usa `modifiers` en su lugar.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"Como un porcentaje de la imagen, la altura a la que recortar la imagen. OBSOLETO: Usa `modifiers` en su lugar.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"Leyenda del adjunto.","type":"object","properties":{"raw":{"description":"Leyenda del adjunto, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Leyenda HTML del adjunto, transformada para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n del adjunto","type":"object","properties":{"raw":{"description":"Descripci\u00f3n del adjunto, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Descripci\u00f3n HTML del adjunto, transformada para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"El ID de las entradas a las que est\u00e1 asociado el adjunto.","type":"integer","required":false},"alt_text":{"description":"Texto alternativo a mostrar cuando no se muestra el adjunto.","type":"string","required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita el conjunto de resultados en base a la relaci\u00f3n entre m\u00faltiples taxonom\u00edas.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda menus.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda menus.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Limitar los resultados a entradas con un valor espec\u00edfico `menu_order`.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"El t\u00edtulo para el objeto.","type":["string","object"],"properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"La familia de objetos representada originalmente, como \u00abpost_type\u00bb o \u00abtaxonom\u00eda\u00bb.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"default":0,"description":"El ID del superior del objeto.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Texto del atributo del t\u00edtulo del elemento del enlace de este elemento del men\u00fa.","type":"string","required":false},"classes":{"description":"Nombres de las clases del elemento del men\u00fa de este elemento del men\u00fa.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La descripci\u00f3n de este elemento del men\u00fa.","type":"string","required":false},"menu_order":{"default":1,"description":"El ID de la BD del nav_menu_item del que es superior este elemento del men\u00fa, si lo hubiera. 0 en caso contrario.","type":"integer","minimum":1,"required":false},"object":{"description":"El tipo de objeto representado originalmente, como \u00abcategor\u00eda\u00bb, \u00abentrada\u00bb o \u00abadjunto\u00bb.","type":"string","required":false},"object_id":{"default":0,"description":"El ID de la base de datos del objeto original que representa este elemento del men\u00fa. Por ejemplo, el ID para las entradas o el `term_id` para las categor\u00edas.","type":"integer","minimum":0,"required":false},"target":{"description":"El atributo de destino del elemento del enlace de este elemento del men\u00fa.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"La URL a la que apunta este elemento del men\u00fa.","type":"string","format":"uri","required":false},"xfn":{"description":"La relaci\u00f3n XFN expresada en el enlace de este elemento del men\u00fa.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda nav_menu.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"title":{"description":"El t\u00edtulo para el objeto.","type":["string","object"],"properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"La familia de objetos representada originalmente, como \u00abpost_type\u00bb o \u00abtaxonom\u00eda\u00bb.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"parent":{"description":"El ID del superior del objeto.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Texto del atributo del t\u00edtulo del elemento del enlace de este elemento del men\u00fa.","type":"string","required":false},"classes":{"description":"Nombres de las clases del elemento del men\u00fa de este elemento del men\u00fa.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La descripci\u00f3n de este elemento del men\u00fa.","type":"string","required":false},"menu_order":{"description":"El ID de la BD del nav_menu_item del que es superior este elemento del men\u00fa, si lo hubiera. 0 en caso contrario.","type":"integer","minimum":1,"required":false},"object":{"description":"El tipo de objeto representado originalmente, como \u00abcategor\u00eda\u00bb, \u00abentrada\u00bb o \u00abadjunto\u00bb.","type":"string","required":false},"object_id":{"description":"El ID de la base de datos del objeto original que representa este elemento del men\u00fa. Por ejemplo, el ID para las entradas o el `term_id` para las categor\u00edas.","type":"integer","minimum":0,"required":false},"target":{"description":"El atributo de destino del elemento del enlace de este elemento del men\u00fa.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"La URL a la que apunta este elemento del men\u00fa.","type":"string","format":"uri","required":false},"xfn":{"description":"La relaci\u00f3n XFN expresada en el enlace de este elemento del men\u00fa.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda nav_menu.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID del superior del objeto.","type":"integer","minimum":0,"required":false},"title":{"description":"El t\u00edtulo para el objeto.","type":["string","object"],"properties":{"raw":{"description":"T\u00edtulo para el objeto, tal y como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para el objeto, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"La familia de objetos representada originalmente, como \u00abpost_type\u00bb o \u00abtaxonom\u00eda\u00bb.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Un nombre de estado para el objeto.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"attr_title":{"description":"Texto del atributo del t\u00edtulo del elemento del enlace de este elemento del men\u00fa.","type":"string","required":false},"classes":{"description":"Nombres de las clases del elemento del men\u00fa de este elemento del men\u00fa.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La descripci\u00f3n de este elemento del men\u00fa.","type":"string","required":false},"menu_order":{"description":"El ID de la BD del nav_menu_item del que es superior este elemento del men\u00fa, si lo hubiera. 0 en caso contrario.","type":"integer","minimum":1,"required":false},"object":{"description":"El tipo de objeto representado originalmente, como \u00abcategor\u00eda\u00bb, \u00abentrada\u00bb o \u00abadjunto\u00bb.","type":"string","required":false},"object_id":{"description":"El ID de la base de datos del objeto original que representa este elemento del men\u00fa. Por ejemplo, el ID para las entradas o el `term_id` para las categor\u00edas.","type":"integer","minimum":0,"required":false},"target":{"description":"El atributo de destino del elemento del enlace de este elemento del men\u00fa.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"La URL a la que apunta este elemento del men\u00fa.","type":"string","format":"uri","required":false},"xfn":{"description":"La relaci\u00f3n XFN expresada en el enlace de este elemento del men\u00fa.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Los t\u00e9rminos asignados al objeto en la taxonom\u00eda nav_menu.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limita el conjunto de resultados en base a la relaci\u00f3n entre m\u00faltiples taxonom\u00edas.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Limitar el conjunto de resultados a los elementos con los t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si los elementos deben ser asignados todos o alguno de los t\u00e9rminos especificados.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Limitar el conjunto de resultados a los elementos, excepto aquellos con t\u00e9rminos espec\u00edficos asignados en la taxonom\u00eda wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Lista de ID de t\u00e9rminos","description":"Emparejar los t\u00e9rminos con los ID listados.","type":"array","items":{"type":"integer"}},{"title":"Consulta de la taxonom\u00eda del ID del t\u00e9rmino","description":"Realiza una consulta avanzada de t\u00e9rminos.","type":"object","properties":{"terms":{"description":"ID del t\u00e9rmino.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"wp_pattern_category":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Anula la longitud por defecto del extracto.","type":"integer","required":false},"password":{"description":"La contrase\u00f1a para la entrada, si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"wp_pattern_category":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"El extracto de la entrada.","type":"object","properties":{"raw":{"description":"Extracto para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Extracto HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"Si el extracto est\u00e1 protegido con una contrase\u00f1a.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false},"wp_pattern_category":{"description":"Los t\u00e9rminos asignados a la entrada en la taxonom\u00eda wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El id de una plantilla","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El id de una plantilla","type":"string","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El id de una plantilla","type":"string","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"El id de una plantilla","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"El id de una plantilla","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica la plantilla.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador del tema para la plantilla.","type":"string","required":false},"type":{"description":"Tipo de plantilla.","type":"string","required":false},"content":{"description":"Contenido de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"Contenido para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la plantilla.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la plantilla, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n de la plantilla.","type":"string","required":false},"status":{"description":"Estado de la plantilla.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"El ID del autor de la plantilla.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El id de una plantilla","type":"string","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limitar al ID de entrada especificado.","type":"integer","required":false},"area":{"description":"Limitar al \u00e1rea de la parte especificada de la plantilla.","type":"string","required":false},"post_type":{"description":"Tipo de contenido para el que obtener las plantillas.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug \u00fanico que identifica la plantilla.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identificador del tema para la plantilla.","type":"string","required":false},"type":{"description":"Tipo de plantilla.","type":"string","required":false},"content":{"default":"","description":"Contenido de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"Contenido para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la plantilla.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"T\u00edtulo de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la plantilla, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Descripci\u00f3n de la plantilla.","type":"string","required":false},"status":{"default":"publish","description":"Estado de la plantilla.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"El ID del autor de la plantilla.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"El slug de la plantilla para conseguir una alternativa","type":"string","required":true},"is_custom":{"description":"Indica si es una plantilla personalizada o forma parte de la jerarqu\u00eda de plantillas","type":"boolean","required":false},"template_prefix":{"description":"El prefijo de la plantilla para la plantilla creada. Se usa para extraer el tipo de plantilla principal, p. ej. en `taxonomia-libros` extrae `taxonomia`","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"El id de una plantilla","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"El id de una plantilla","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica la plantilla.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador del tema para la plantilla.","type":"string","required":false},"type":{"description":"Tipo de plantilla.","type":"string","required":false},"content":{"description":"Contenido de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"Contenido para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la plantilla.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la plantilla, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n de la plantilla.","type":"string","required":false},"status":{"description":"Estado de la plantilla.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"El ID del autor de la plantilla.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"El id de una plantilla","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El id de una plantilla","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El id de una plantilla","type":"string","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El id de una plantilla","type":"string","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"El id de una plantilla","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"El id de una plantilla","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica la plantilla.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador del tema para la plantilla.","type":"string","required":false},"type":{"description":"Tipo de plantilla.","type":"string","required":false},"content":{"description":"Contenido de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"Contenido para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la plantilla.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la plantilla, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n de la plantilla.","type":"string","required":false},"status":{"description":"Estado de la plantilla.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"El ID del autor de la plantilla.","type":"integer","required":false},"area":{"description":"D\u00f3nde se pretende usar la parte de la plantilla (cabecera, pie de p\u00e1gina, etc.)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El id de una plantilla","type":"string","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limitar al ID de entrada especificado.","type":"integer","required":false},"area":{"description":"Limitar al \u00e1rea de la parte especificada de la plantilla.","type":"string","required":false},"post_type":{"description":"Tipo de contenido para el que obtener las plantillas.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug \u00fanico que identifica la plantilla.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identificador del tema para la plantilla.","type":"string","required":false},"type":{"description":"Tipo de plantilla.","type":"string","required":false},"content":{"default":"","description":"Contenido de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"Contenido para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la plantilla.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"T\u00edtulo de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la plantilla, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Descripci\u00f3n de la plantilla.","type":"string","required":false},"status":{"default":"publish","description":"Estado de la plantilla.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"El ID del autor de la plantilla.","type":"integer","required":false},"area":{"description":"D\u00f3nde se pretende usar la parte de la plantilla (cabecera, pie de p\u00e1gina, etc.)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"El slug de la plantilla para conseguir una alternativa","type":"string","required":true},"is_custom":{"description":"Indica si es una plantilla personalizada o forma parte de la jerarqu\u00eda de plantillas","type":"boolean","required":false},"template_prefix":{"description":"El prefijo de la plantilla para la plantilla creada. Se usa para extraer el tipo de plantilla principal, p. ej. en `taxonomia-libros` extrae `taxonomia`","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"El id de una plantilla","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"El id de una plantilla","type":"string","required":false},"slug":{"description":"Slug \u00fanico que identifica la plantilla.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identificador del tema para la plantilla.","type":"string","required":false},"type":{"description":"Tipo de plantilla.","type":"string","required":false},"content":{"description":"Contenido de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"Contenido para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit"]},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la plantilla.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"T\u00edtulo de la plantilla.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la plantilla, tal como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la plantilla, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Descripci\u00f3n de la plantilla.","type":"string","required":false},"status":{"description":"Estado de la plantilla.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"author":{"description":"El ID del autor de la plantilla.","type":"integer","required":false},"area":{"description":"D\u00f3nde se pretende usar la parte de la plantilla (cabecera, pie de p\u00e1gina, etc.)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"El id de una plantilla","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n de estilos globales.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n de estilos globales.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"El identificador del tema","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"El identificador del tema","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"ID de la configuraci\u00f3n de estilos globales.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Estilos globales.","type":["object"],"required":false},"settings":{"description":"Ajustes globales.","type":["object"],"required":false},"title":{"description":"T\u00edtulo de la variaci\u00f3n de estilos globales.","type":["object","string"],"properties":{"raw":{"description":"T\u00edtulo para la variaci\u00f3n de estilos globales, tal y como existe en la base de datos.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"La contrase\u00f1a para la entrada, si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del objeto.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"El ID del superior de la revisi\u00f3n.","type":"integer","required":false},"id":{"description":"Identificador \u00fanico para la revisi\u00f3n.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que las revisiones no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit","embed"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Versi\u00f3n del schema theme.json usado para los ajustes de tipograf\u00eda.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"Declaraci\u00f3n font-family en formato theme.json, codificada como cadena.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"theme_json_version":{"description":"Versi\u00f3n del schema theme.json usado para los ajustes de tipograf\u00eda.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"Declaraci\u00f3n font-family en formato theme.json, codificada como cadena.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"El ID de la familia de fuentes padre de la fuente.","type":"integer","required":true},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"El ID de la familia de fuentes padre de la fuente.","type":"integer","required":true},"theme_json_version":{"description":"Versi\u00f3n del schema theme.json usado para los ajustes de tipograf\u00eda.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"Declaraci\u00f3n font-face en formato theme.json, codificada como cadena.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"El ID de la familia de fuentes padre de la fuente.","type":"integer","required":true},"id":{"description":"Identificador \u00fanico para el font face.","type":"integer","required":true},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"El ID de la familia de fuentes padre de la fuente.","type":"integer","required":true},"id":{"description":"Identificador \u00fanico para el font face.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/videoplayer":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/videoplayer"}]}},"\/wp\/v2\/videoplayer\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"La contrase\u00f1a para la entrada, si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/videoplayer\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"title":{"description":"El t\u00edtulo para la entrada.","type":"object","properties":{"raw":{"description":"T\u00edtulo para la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"T\u00edtulo HTML para la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}}]},"\/wp\/v2\/videoplayer\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/rm_content_editor":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a entradas publicadas despu\u00e9s de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limitar la respuesta a las entradas modificadas despu\u00e9s de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limitar la respuesta a entradas publicadas antes de una fecha dada compatible con ISO9601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limitar la respuesta a las entradas modificadas antes de una fecha determinada conforme a la norma ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"C\u00f3mo interpretar la entrada de b\u00fasqueda.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limitar el conjunto de resultados a las entradas con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limitar el conjunto de resultados a las entradas asignadas a uno o m\u00e1s estados.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/rm_content_editor"}]}},"\/wp\/v2\/rm_content_editor\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"La contrase\u00f1a para la entrada, si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico de la entrada.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false}}}]},"\/wp\/v2\/rm_content_editor\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"date":{"description":"La fecha en la que se public\u00f3 la entrada, en la zona horaria del sitio.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que la entrada fue publicada, como GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para la entrada, \u00fanico para su tipo.","type":"string","required":false},"status":{"description":"Un nombre de estado de la entrada.","type":"string","enum":["publish","future","draft","pending","private"],"required":false},"password":{"description":"Una contrase\u00f1a para proteger el acceso al contenido y al extracto.","type":"string","required":false},"content":{"description":"El contenido de la entrada.","type":"object","properties":{"raw":{"description":"Contenido de la entrada, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML de la entrada, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Versi\u00f3n del formato del bloque de contenido usado por la entrada.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"Si el contenido est\u00e1 protegido con contrase\u00f1a o no.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"El archivo del tema a usar para mostrar la entrada.","type":"string","required":false}}}]},"\/wp\/v2\/rm_content_editor\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"El ID para el superior del guardado autom\u00e1tico.","type":"integer","required":false},"id":{"description":"El ID para el guardado autom\u00e1tico.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Un identificador alfanum\u00e9rico del tipo de contenido.","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Un identificador alfanum\u00e9rico del estado.","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Limitar los resultados a taxonom\u00edas asociadas con un tipo de contenido espec\u00edfico.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Un identificador alfanum\u00e9rico de la taxonom\u00eda.","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo de t\u00e9rmino.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Si se ocultar\u00e1n o no los t\u00e9rminos asignados a cualquier entrada.","type":"boolean","default":false,"required":false},"parent":{"description":"Limitar el resultado a t\u00e9rminos asignados a un superior espec\u00edfico.","type":"integer","required":false},"post":{"description":"Limitar el resultado a t\u00e9rminos asignados a una entrada espec\u00edfica.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar el resultado a t\u00e9rminos con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descripci\u00f3n HTML del t\u00e9rmino.","type":"string","required":false},"name":{"description":"T\u00edtulo HTML del t\u00e9rmino.","type":"string","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el t\u00e9rmino \u00fanico para su tipo.","type":"string","required":false},"parent":{"description":"Identificador del t\u00e9rmino superior.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del t\u00e9rmino.","type":"string","required":false},"name":{"description":"T\u00edtulo HTML del t\u00e9rmino.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el t\u00e9rmino \u00fanico para su tipo.","type":"string","required":false},"parent":{"description":"Identificador del t\u00e9rmino superior.","type":"integer","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que los t\u00e9rminos no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo de t\u00e9rmino.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Si se ocultar\u00e1n o no los t\u00e9rminos asignados a cualquier entrada.","type":"boolean","default":false,"required":false},"post":{"description":"Limitar el resultado a t\u00e9rminos asignados a una entrada espec\u00edfica.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar el resultado a t\u00e9rminos con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descripci\u00f3n HTML del t\u00e9rmino.","type":"string","required":false},"name":{"description":"T\u00edtulo HTML del t\u00e9rmino.","type":"string","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el t\u00e9rmino \u00fanico para su tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del t\u00e9rmino.","type":"string","required":false},"name":{"description":"T\u00edtulo HTML del t\u00e9rmino.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el t\u00e9rmino \u00fanico para su tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que los t\u00e9rminos no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo de t\u00e9rmino.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Si se ocultar\u00e1n o no los t\u00e9rminos asignados a cualquier entrada.","type":"boolean","default":false,"required":false},"post":{"description":"Limitar el resultado a t\u00e9rminos asignados a una entrada espec\u00edfica.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar el resultado a t\u00e9rminos con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descripci\u00f3n HTML del t\u00e9rmino.","type":"string","required":false},"name":{"description":"T\u00edtulo HTML del t\u00e9rmino.","type":"string","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el t\u00e9rmino \u00fanico para su tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"locations":{"description":"Las ubicaciones asignadas al men\u00fa.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Si quieres a\u00f1adir autom\u00e1ticamente las p\u00e1ginas de nivel superior a este men\u00fa.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del t\u00e9rmino.","type":"string","required":false},"name":{"description":"T\u00edtulo HTML del t\u00e9rmino.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el t\u00e9rmino \u00fanico para su tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false},"locations":{"description":"Las ubicaciones asignadas al men\u00fa.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Si quieres a\u00f1adir autom\u00e1ticamente las p\u00e1ginas de nivel superior a este men\u00fa.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que los t\u00e9rminos no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por atributo de t\u00e9rmino.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"Si se ocultar\u00e1n o no los t\u00e9rminos asignados a cualquier entrada.","type":"boolean","default":false,"required":false},"post":{"description":"Limitar el resultado a t\u00e9rminos asignados a una entrada espec\u00edfica.","type":"integer","default":null,"required":false},"slug":{"description":"Limitar el resultado a t\u00e9rminos con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Descripci\u00f3n HTML del t\u00e9rmino.","type":"string","required":false},"name":{"description":"T\u00edtulo HTML del t\u00e9rmino.","type":"string","required":true},"slug":{"description":"Un identificador alfanum\u00e9rico para el t\u00e9rmino \u00fanico para su tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"description":{"description":"Descripci\u00f3n HTML del t\u00e9rmino.","type":"string","required":false},"name":{"description":"T\u00edtulo HTML del t\u00e9rmino.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico para el t\u00e9rmino \u00fanico para su tipo.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del t\u00e9rmino.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que los t\u00e9rminos no son compatibles con el env\u00edo a la papelera.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"default":"asc","description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Ordenar la colecci\u00f3n por el atributo del usuario.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Limitar el resultado a usuarios con uno o m\u00e1s slugs espec\u00edficos.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Limitar el resultado a usuarios que se ajusten al menos a un perfil espec\u00edfico facilitado. Acepta listas en CSV o un solo perfil.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Limita el conjunto de resultados a usuarios que coincidan, al menos, con una capacidad espec\u00edfica proporcionada. Acepta listas en CSV o una \u00fanica capacidad.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Limitar el resultado a usuarios considerados autores.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Limitar el resultado a usuarios que han publicado entradas.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","videoplayer":"videoplayer","rm_content_editor":"rm_content_editor"}},"required":false},"search_columns":{"default":[],"description":"Array de nombres de columnas que se van a buscar.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Nombre de acceso del usuario.","type":"string","required":true},"name":{"description":"Muestra el nombre del usuario.","type":"string","required":false},"first_name":{"description":"Nombre del usuario.","type":"string","required":false},"last_name":{"description":"Apellidos del usuario.","type":"string","required":false},"email":{"description":"La direcci\u00f3n de correo electr\u00f3nico del usuario.","type":"string","format":"email","required":true},"url":{"description":"URL del usuario.","type":"string","format":"uri","required":false},"description":{"description":"Descripci\u00f3n del usuario.","type":"string","required":false},"locale":{"description":"Idioma local del usuario.","type":"string","enum":["","en_US","es_ES","es_VE"],"required":false},"nickname":{"description":"Alias del usuario.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico del usuario.","type":"string","required":false},"roles":{"description":"Perfiles asignados al usuario.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Contrase\u00f1a del usuario (no incluida).","type":"string","required":true},"meta":{"description":"Campos meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"La fecha y hora en que se actualizaron las preferencias.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del usuario.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del usuario.","type":"integer","required":false},"username":{"description":"Nombre de acceso del usuario.","type":"string","required":false},"name":{"description":"Muestra el nombre del usuario.","type":"string","required":false},"first_name":{"description":"Nombre del usuario.","type":"string","required":false},"last_name":{"description":"Apellidos del usuario.","type":"string","required":false},"email":{"description":"La direcci\u00f3n de correo electr\u00f3nico del usuario.","type":"string","format":"email","required":false},"url":{"description":"URL del usuario.","type":"string","format":"uri","required":false},"description":{"description":"Descripci\u00f3n del usuario.","type":"string","required":false},"locale":{"description":"Idioma local del usuario.","type":"string","enum":["","en_US","es_ES","es_VE"],"required":false},"nickname":{"description":"Alias del usuario.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico del usuario.","type":"string","required":false},"roles":{"description":"Perfiles asignados al usuario.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Contrase\u00f1a del usuario (no incluida).","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"La fecha y hora en que se actualizaron las preferencias.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del usuario.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que los usuarios no son compatibles con el env\u00edo a la papelera.","required":false},"reassign":{"type":"integer","description":"Reasignando las entradas y los enlaces del usuario borrados a la ID de este usuario.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Nombre de acceso del usuario.","type":"string","required":false},"name":{"description":"Muestra el nombre del usuario.","type":"string","required":false},"first_name":{"description":"Nombre del usuario.","type":"string","required":false},"last_name":{"description":"Apellidos del usuario.","type":"string","required":false},"email":{"description":"La direcci\u00f3n de correo electr\u00f3nico del usuario.","type":"string","format":"email","required":false},"url":{"description":"URL del usuario.","type":"string","format":"uri","required":false},"description":{"description":"Descripci\u00f3n del usuario.","type":"string","required":false},"locale":{"description":"Idioma local del usuario.","type":"string","enum":["","en_US","es_ES","es_VE"],"required":false},"nickname":{"description":"Alias del usuario.","type":"string","required":false},"slug":{"description":"Un identificador alfanum\u00e9rico del usuario.","type":"string","required":false},"roles":{"description":"Perfiles asignados al usuario.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Contrase\u00f1a del usuario (no incluida).","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"La fecha y hora en que se actualizaron las preferencias.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Es necesario que sea \u00abtrue\u00bb, ya que los usuarios no son compatibles con el env\u00edo a la papelera.","required":false},"reassign":{"type":"integer","description":"Reasignando las entradas y los enlaces del usuario borrados a la ID de este usuario.","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"Un UUID proporcionado por la aplicaci\u00f3n para identificarla de forma \u00fanica. Se recomienda usar un UUID v5 con la URL o el espacio de nombres DNS.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"El nombre de la contrase\u00f1a de la aplicaci\u00f3n.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"Un UUID proporcionado por la aplicaci\u00f3n para identificarla de forma \u00fanica. Se recomienda usar un UUID v5 con la URL o el espacio de nombres DNS.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"El nombre de la contrase\u00f1a de la aplicaci\u00f3n.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"after":{"description":"Limitar la respuesta a comentarios publicados despu\u00e9s de una fecha dada compatible con ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limitar el conjunto de resultados a comentarios asignados a identificadores de usuario espec\u00edficos. Necesita autorizaci\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"Asegurar que el conjunto de resultados excluye los comentarios asignados a IDs de usuario espec\u00edficos. Necesita autorizaci\u00f3n.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Limitar el conjunto de resultados a aquellos con un correo electr\u00f3nico de autor espec\u00edfico. Necesita autorizaci\u00f3n.","format":"email","type":"string","required":false},"before":{"description":"Limitar la respuesta a comentarios publicados antes de una fecha dada compatible con ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo del comentario.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Limitar el resultado a comentarios con ID superiores espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"Asegurar que el conjunto de resultados excluya los IDs superiores espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Limitar el resultado a comentarios asignados a IDs de entrada espec\u00edficos.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Limitar el conjunto de resultados a los comentarios asignados a un estado espec\u00edfico. Necesita autorizaci\u00f3n.","type":"string","required":false},"type":{"default":"comment","description":"Limitar el conjunto de resultados a los comentarios asignados a un tipo espec\u00edfico. Necesita autorizaci\u00f3n.","type":"string","required":false},"password":{"description":"La contrase\u00f1a para la entrada, si est\u00e1 protegida por contrase\u00f1a.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"El ID del objeto del usuario, si el autor era un usuario.","type":"integer","required":false},"author_email":{"description":"Direcci\u00f3n de correo electr\u00f3nico del autor del comentario.","type":"string","format":"email","required":false},"author_ip":{"description":"Direcci\u00f3n IP del autor del comentario.","type":"string","format":"ip","required":false},"author_name":{"description":"Muestra el nombre del autor del comentario.","type":"string","required":false},"author_url":{"description":"URL del autor del comentario.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Agente de usuario del autor del comentario.","type":"string","required":false},"content":{"description":"El contenido para el comentario.","type":"object","properties":{"raw":{"description":"Contenido para el comentario, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML para el comentario, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"La fecha en la que se public\u00f3 el comentario, en la zona horaria del sitio.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que el comentario fue publicado, como GMT.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"El ID del superior del comentario.","type":"integer","required":false},"post":{"default":0,"description":"El ID del objeto asociado a la entrada.","type":"integer","required":false},"status":{"description":"Estado del comentario.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Estado de resoluci\u00f3n de la nota","default":"","enum":["resolved","reopen"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identificador \u00fanico para el comentario.","type":"integer","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"La contrase\u00f1a de la entrada superior del comentario (si la entrada est\u00e1 protegida por contrase\u00f1a).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identificador \u00fanico para el comentario.","type":"integer","required":false},"author":{"description":"El ID del objeto del usuario, si el autor era un usuario.","type":"integer","required":false},"author_email":{"description":"Direcci\u00f3n de correo electr\u00f3nico del autor del comentario.","type":"string","format":"email","required":false},"author_ip":{"description":"Direcci\u00f3n IP del autor del comentario.","type":"string","format":"ip","required":false},"author_name":{"description":"Muestra el nombre del autor del comentario.","type":"string","required":false},"author_url":{"description":"URL del autor del comentario.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Agente de usuario del autor del comentario.","type":"string","required":false},"content":{"description":"El contenido para el comentario.","type":"object","properties":{"raw":{"description":"Contenido para el comentario, tal como existe en la base de datos.","type":"string","context":["edit"]},"rendered":{"description":"Contenido HTML para el comentario, transformado para su visualizaci\u00f3n.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"La fecha en la que se public\u00f3 el comentario, en la zona horaria del sitio.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"La fecha en la que el comentario fue publicado, como GMT.","type":"string","format":"date-time","required":false},"parent":{"description":"El ID del superior del comentario.","type":"integer","required":false},"post":{"description":"El ID del objeto asociado a la entrada.","type":"integer","required":false},"status":{"description":"Estado del comentario.","type":"string","required":false},"meta":{"description":"Campos meta.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"Estado de resoluci\u00f3n de la nota","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identificador \u00fanico para el comentario.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Si se evita la papelera y se fuerza el borrado.","required":false},"password":{"description":"La contrase\u00f1a de la entrada superior del comentario (si la entrada est\u00e1 protegida por contrase\u00f1a).","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"type":{"default":"post","description":"Limitar los resultados a elementos de un tipo de objeto.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Limitar los resultados a elementos de uno o m\u00e1s subtipos de objetos.","type":"array","items":{"enum":["post","page","category","post_tag","any"],"type":"string"},"required":false},"exclude":{"description":"Asegurar que el conjunto de resultados excluye IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limitar el conjunto de resultados a IDs espec\u00edficos.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Nombre \u00fanico registrado para el bloque.","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Atributos para el bloque.","type":"object","default":[],"required":false},"post_id":{"description":"ID del contexto de la entrada.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Espacio de nombres del bloque.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Espacio de nombres del bloque.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Nombre del bloque.","type":"string","required":false},"namespace":{"description":"Espacio de nombres del bloque.","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"title":{"title":"T\u00edtulo","description":"T\u00edtulo del sitio.","type":"string","required":false},"description":{"title":"Descripci\u00f3n corta","description":"Descripci\u00f3n corta del sitio.","type":"string","required":false},"url":{"title":"","description":"URL del sitio.","type":"string","format":"uri","required":false},"email":{"title":"","description":"Esta direcci\u00f3n se utiliza para fines de administraci\u00f3n, por ejemplo, avisos de nuevos usuarios.","type":"string","format":"email","required":false},"timezone":{"title":"","description":"Una ciudad en la misma zona horaria que t\u00fa.","type":"string","required":false},"date_format":{"title":"","description":"Formato fecha para todas las cadenas de fecha.","type":"string","required":false},"time_format":{"title":"","description":"Formato de hora para todas las cadenas de hora.","type":"string","required":false},"start_of_week":{"title":"","description":"El n\u00famero de d\u00eda en el que la semana debe comenzar.","type":"integer","required":false},"language":{"title":"","description":"C\u00f3digo del idioma local de WordPress.","type":"string","required":false},"use_smilies":{"title":"","description":"Convierte emoticonos como :-) y :-P en gr\u00e1ficos en la pantalla.","type":"boolean","required":false},"default_category":{"title":"","description":"Categoria de entrada por defecto","type":"integer","required":false},"default_post_format":{"title":"","description":"Formato de la entrada por defecto.","type":"string","required":false},"posts_per_page":{"title":"Entradas m\u00e1ximas por p\u00e1gina","description":"P\u00e1ginas de blog mostradas como m\u00e1ximo.","type":"integer","required":false},"show_on_front":{"title":"Mostrar en la portada","description":"Qu\u00e9 mostrar en la p\u00e1gina de inicio","type":"string","required":false},"page_on_front":{"title":"P\u00e1gina en la portada","description":"El ID de la p\u00e1gina que debe mostrarse en la p\u00e1gina de inicio","type":"integer","required":false},"page_for_posts":{"title":"","description":"El ID de la p\u00e1gina que debe mostrar las \u00faltimas entradas","type":"integer","required":false},"default_ping_status":{"title":"","description":"Permite avisos de enlaces desde otros sitios (pingbacks y trackbacks) en los nuevos art\u00edculos.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Permitir comentarios en las entradas nuevas","description":"Permitir a la gente enviar comentarios en las nuevas entradas.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logotipo","description":"Logotipo del sitio.","type":"integer","required":false},"site_icon":{"title":"Icono","description":"Icono del sitio.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Limitar el conjunto de resultados a los temas asignados a uno o m\u00e1s estados. ","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"La hoja de estilos del tema. Esto identifica el tema de forma \u00fanica.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","required":false},"status":{"description":"Limita los resultados a plugins con el estado dado.","type":"array","items":{"type":"string","enum":["inactive","active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"Slug del plugin en el directorio WordPress.org.","pattern":"[\\w\\-]+","required":true},"status":{"description":"Estado de activaci\u00f3n del plugin.","type":"string","enum":["inactive","active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"Estado de activaci\u00f3n del plugin.","type":"string","enum":["inactive","active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"El ID de una barra lateral registrada","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Widgets anidados.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"El ID del tipo de widget.","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"El ID del tipo de widget.","type":"string","required":true},"instance":{"description":"Ajustes de la instancia actual del widget.","type":"object","required":false},"form_data":{"description":"Datos serializados de formulario de widget para cifrar en los ajustes de la instancia.","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"El ID del tipo de widget.","type":"string","required":true},"instance":{"description":"Ajustes de la instancia actual del widget.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"La barra lateral a la que devolver el widget.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del widget.","type":"string","required":false},"id_base":{"description":"El tipo de widget. Corresponde al ID en la variable widget-types.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"La barra lateral a la que pertenece el widget.","type":"string","required":true},"instance":{"description":"Ajustes de la instancia del widget, si es compatible.","type":"object","properties":{"encoded":{"description":"Representaci\u00f3n base64 cifrada de los ajustes de la instancia.","type":"string","context":["edit"]},"hash":{"description":"Hash criptogr\u00e1fico de los ajustes de la instancia.","type":"string","context":["edit"]},"raw":{"description":"Ajustes de instancia sin cifrar, si es compatible.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Datos de formulario cifrados por URL del formulario de administraci\u00f3n del widget. Se usa para actualizar un widget que no tenga compatibilidad con instancias. Solo escritura.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificador \u00fanico del widget.","type":"string","required":false},"id_base":{"description":"El tipo de widget. Corresponde al ID en la variable widget-types.","type":"string","required":false},"sidebar":{"description":"La barra lateral a la que pertenece el widget.","type":"string","required":false},"instance":{"description":"Ajustes de la instancia del widget, si es compatible.","type":"object","properties":{"encoded":{"description":"Representaci\u00f3n base64 cifrada de los ajustes de la instancia.","type":"string","context":["edit"]},"hash":{"description":"Hash criptogr\u00e1fico de los ajustes de la instancia.","type":"string","context":["edit"]},"raw":{"description":"Ajustes de instancia sin cifrar, si es compatible.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Datos de formulario cifrados por URL del formulario de administraci\u00f3n del widget. Se usa para actualizar un widget que no tenga compatibilidad con instancias. Solo escritura.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Si forzar la eliminaci\u00f3n del widget o moverlo a la barra lateral inactiva.","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Limitar el resultado a bloques que coincidan con el t\u00e9rmino de b\u00fasqueda.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limitar los resultados a aquellos que coinciden con una cadena.","type":"string","minLength":1,"required":false},"category":{"description":"Limitar los resultados a los que coincidan con un ID de categor\u00eda.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Limitar resultados a los que coincidan con el ID de una palabra clave.","type":"integer","minimum":1,"required":false},"slug":{"description":"Limita los resultados a los que coinciden con un patr\u00f3n (slug).","type":"array","required":false},"offset":{"description":"Desplazar el conjunto de resultados un n\u00famero espec\u00edfico de elementos.","type":"integer","required":false},"order":{"description":"Orden de clasificaci\u00f3n de atributos ascendente o descendente.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Ordenar la colecci\u00f3n por el atributo de la entrada.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"La URL a procesar.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Un identificador alfanum\u00e9rico de la ubicaci\u00f3n del men\u00fa.","type":"string","required":false},"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Identificador \u00fanico de la categor\u00eda de capacidad.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Identificador \u00fanico de la hab\u00edlidad.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Par\u00e1metros de entrada para la ejecuci\u00f3n de la capacidad.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"\u00c1mbito de aplicaci\u00f3n de la solicitud; determina los campos presentes en la respuesta.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"P\u00e1gina actual de la colecci\u00f3n.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"N\u00famero m\u00e1ximo de elementos que se devolver\u00e1n en el conjunto de resultados.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Limita los resultados a capacidades en la categor\u00eda de capacidad espec\u00edfica.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/vespania.es\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Identificador \u00fanico de la hab\u00edlidad.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}}]}},"site_logo":0,"site_icon":4053,"site_icon_url":"https:\/\/ex3qgcecnzv.exactdn.com\/wp-content\/uploads\/2016\/01\/cropped-escudo_vespania.jpg?strip=all","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_icon","href":"https:\/\/vespania.es\/wp-json\/wp\/v2\/media\/4053"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
